968 Forum 1992-1995
Something's still spinning after I turn off the ignition
Old 01-13-2004, 02:19 AM
gnosis
gnosis's Avatar
Default Something's still spinning after I turn off the ignition
When I turn off my ignition, the engine stops, and I hear what sounds like a noisy bearing spinning down slowly. It takes about 5 seconds to stop. I can only hear it if I have the hood up, so it's not all that noisy. It's just that I don't recall it happening in the past. Any ideas what part this might be?
The car has air conditioning, for what it's worth.
Clayton
Old 01-13-2004, 09:41 AM
RajDatta
RajDatta's Avatar
Does this happen when the AC is on? If so, your bearing on the sondensor might be going south. Wait a sec, you are as far south as it goes (AUS), lol.
Old 01-13-2004, 10:23 AM
gnosis
gnosis's Avatar
I'll have to check and compare A/C on and off. Although my guess is that when I last heard it, the A/C was off.
Clayton
Old 01-13-2004, 10:29 AM
RajDatta
RajDatta's Avatar
Gnosis, there are 2 parts to the AC compressor, one parts that spins all the time with the AC belt and the other operated by a clutch which engages when you turn your AC off.
I get a feeling your bearings on the compressor are making that noise. See if you can isolate the area.
Old 01-13-2004, 11:20 AM
gnosis
gnosis's Avatar
Okay. I'm about to replace belts etc. so while I'm in there I'll do some tests centred around the A/C unit.
Thanks,
Clayton
Old 01-13-2004, 01:01 PM
nedkelly
nedkelly's Avatar
Location: Expat Scouser living in Dubai, United Arab Emirates
Clayton,
Check it's not one of the cooling fans bearings squealing on it's run down. You can pull the fuse for 1 fan which will cause the other to go into warp speed and this should give you time to listen to it running down. Replace fuse for fan 1 and repeat for fan 2. It's a 2 minute check and will at least allow you you chalk the fans off the check list. I'm brand new to these cars so I could be talking complete and utter rubbish of course!
Old 01-13-2004, 02:22 PM
RajDatta
RajDatta's Avatar
Ned, excellent call. Sometimes the fan can rub against the shroud and create similar sounds as well.
Old 01-13-2004, 08:54 PM
gnosis
gnosis's Avatar
Will do. Thanks.
Clayton
Quick Reply: Something's still spinning after I turn off the ignition
