993 Forum 1995-1998
How tight is 30 inch pounds?
Old 09-13-2004, 08:16 PM
Jastx
Jastx's Avatar
Question How tight is 30 inch pounds?
I am installing the SmarTire tire pressure monitoring system in conjunction with mounting some new tires. The instructions say to tighten the stainless steel strap that holds the sensor inside the tire to 30 inch pounds.
I have a torque wrench but it doesn't go down to inch pounds so I am asking how tight is 30 inch pounds relatively speaking? Can you describe it?
(Can't wait to see the smart-aleck answers )
Old 09-13-2004, 08:29 PM
Dudley
Dudley's Avatar
Ok - I'll bite. What about 2.5 foot lbs?
I would assume if it was "snugged up" you would be fine.
Dave
Old 09-13-2004, 08:37 PM
Ron
Ron's Avatar
Relatively speaking; not very tight. 30 in lbs is the lowest setting on my 1/4" torque wrench. I'm thinking it's probably only finger tight with a 1/4" ratchet, but of couse that's rather vague too.
Maybe it would be a good idea to put some blue loctite on the bolt that holds that thing in there too.
Old 09-13-2004, 09:05 PM
FlyYellow
FlyYellow's Avatar
ok - when faced with these problems i do the obvious thing. Just google it.
30 Inch-Pounds = 2.5 Foot-Pounds
here's where to get the answer.
http://www.sciencelab.com/data/conve...nversion.shtml
hope that helps.
cheers,
boris
Old 09-13-2004, 10:48 PM
kary993
kary993's Avatar
Let's see 30 in/lbs divided by 12 in/lbs (1 ft/lbs) = 2.5 ft/lbs...make sense?
Old 09-13-2004, 11:01 PM
OldGuy
OldGuy's Avatar
Kary did you use a scientific calculator?!
This is a trick question right?
Old 09-13-2004, 11:09 PM
kary993
kary993's Avatar
No calculator, why do you ask ?
Old 09-13-2004, 11:30 PM
OldGuy
OldGuy's Avatar
Cause Kary 30 divided by 12 is ... well like higher math!
Old 09-13-2004, 11:54 PM
kary993
kary993's Avatar
Paul, I had to figure out how to do long division because my calculator ran outof batteries :-)
Old 09-14-2004, 12:09 AM
OldGuy
OldGuy's Avatar
Kary I have an HP reverse polish notation one that has a finger treadmill on it and you can recharge it by letting your fingers do the charging!!
Old 09-14-2004, 10:13 AM
Ray Calvo
Passed On
Ray Calvo's Avatar
About equal to grabbing a 1/4" ratchet wrench by the head with your fingertips and twisting the head. Prob. come close.
Then again, could go out and buy a danged torque wrench with the proper range, cheapskate.
Old 09-14-2004, 11:06 AM
Jastx
Jastx's Avatar
Ray's answer is closest to what I was looking for. My torque wrench goes down to 25 foot pounds. I wanted an idea of how tight the feel should be if I just used a ratchet.
I'll suck it up and buy the darn wrench...
Thanks everyone!
Old 09-14-2004, 11:23 AM
aam993
aam993's Avatar
Here is my description: take 2.5ft long wrench, put it around the nut, apply 1 pound of force(tie 1lb bag of potatoes) to the other end of the wrench - that's how much 2.5ft/lb torque is.
Old 09-14-2004, 01:14 PM
Jastx
Jastx's Avatar
Thanks small....what kind of potatoes should that be?
Quick Reply: How tight is 30 inch pounds?
