996 Turbo Forum 1999-2005
Brake Rotor Thickness for 996 Turbo?
Old 01-15-2005, 07:24 PM
JakeMate
JakeMate's Avatar
Default Brake Rotor Thickness for 996 Turbo?
Does anyone have the brake rotor thickness specs for new, minimum machined, and minimum for 996 Turbo?
Old 01-15-2005, 08:25 PM
okbarnett
okbarnett's Avatar
fronts are min 26mm
Old 01-19-2005, 01:39 AM
JakeMate
JakeMate's Avatar
Just measured my rotors and found the Min. stamped on them too. Here's the thickness data:
Front Min: 32mm = 1.260"
Rear Min: 26mm = 1.024"
Mine measured 1.300" Front
and 1.075" Rear
I'm thinking that they're original rotors but I'm not sure. I have about 24000 miles on the clock. I bought it at 16900.
Old 01-19-2005, 03:32 PM
GreggT
GreggT's Avatar
New they are 34 / 28.
Min after machining* is actually 32.6 / 26.6
*disc must be reworked symetrically, ie both sides evenly
Yep......wear limet is 32 / 26
I'd jotted this down long time ago.......probably credit Loren.
Old 01-19-2005, 06:16 PM
okbarnett
okbarnett's Avatar
Yes, front is 32 min and rear is 26 min.
I looked up wrong part numbers
Old 01-19-2005, 11:35 PM
JakeMate
JakeMate's Avatar
Cool....I think we all have it now.
Old 06-18-2011, 11:01 AM
Musclehedz101
Musclehedz101's Avatar
Are these same specs for 997.1 C4S?
Quick Reply: Brake Rotor Thickness for 996 Turbo?
