ABS Problem Resolved.
Old 05-09-2006, 11:12 PM
Sysgen
Sysgen's Avatar
Default ABS Problem Resolved.
I'm sharing my experience in fixing my ABS problem so as to help others that may have the same problem.
The ____!____ light was comming on after the car started moving. So right away that told me that the ABS control unit was ok and that the problem was with the speed sensors. But which one and why?
To easily find which one I did the following:
Disconnect the connector on the ABS control unit located on the passenger side, just to the right of the glove box by removing the two small screws circled in the first image.
Press the small ears circled on image2 to remove the connector. You end up with the connector on image 3.
Using an ohmmeter you should be mesuring ~1000ohm on each speed sensor.
Front Right, PIN 11 and 21
Front Left, PIN 4 and 6
Rear Right, PIN 24 and 26
Rear Left, PIN 8 and 9
In my case, the rear right, (which by the way is to your right sitting in the car), was mesuring 0 ohm, meaning that either the cable was cut somewhere or something was not connected correctly. it was the small connector below the rear brakes that connects the brake pads sensor and the ABS speed sensor, the cable was not pushed in correctly.
This procedure allowed me to find the problem in around 15 minutes, without having to remove every wheels
Stephane, '90 S2
Old 05-10-2006, 12:25 AM
951Boost
951Boost's Avatar
Great tip Sysgen, thanks for sharing.
Old 10-28-2006, 03:00 PM
Lanny Curlett
Lanny Curlett's Avatar
Thanks so much for that tip. The light doesn't come on until the car is moving so it must be a sensor and I will track it down using the described process. many thanks!!
Lanny
Old 10-28-2006, 03:06 PM
Rock
Lazer Beam Shooter
Rock's Avatar
Hey hey! Same here! When that light is on, does it mean the ABS is disabled?
Old 10-28-2006, 06:30 PM
Sysgen
Sysgen's Avatar
If the computer cannot detect all 4 wheel movement it disables the ABS. The ABS system relies on wheel speed to determine how much brake pressure to apply.
Old 10-28-2006, 08:57 PM
nickg
nickg's Avatar
well if anyone needs abs parts, i have the complete setup and a few of the computers i'd sell cheap
Old 10-28-2006, 09:03 PM
rberry951
Temprarily Banned per IB
rberry951's Avatar
This thread sparked a question I've had for a long time, is there a safe way to disable the ABS and get real non-ABS behavior from the brakes? Just always been curious on this.
Old 10-28-2006, 11:20 PM
Sysgen
Sysgen's Avatar
Disconnect one of the speed sensors
But you`ll always have the ! light on and the Antilock also.
Old 10-28-2006, 11:22 PM
Rock
Lazer Beam Shooter
Rock's Avatar
Simpler, pull the fuse!
Old 06-28-2011, 12:05 AM
928NZ
8th Gear
928NZ's Avatar
If the ABS fails after you start moving it has failed it's self test. In my case it is probably the hydraulic ABS pump which attempted to cycle through a self test. It is not necessarily a speed sensor.
Old 04-20-2012, 09:50 AM
liveinadive1
5th Gear
liveinadive1's Avatar
Hi
This is my first post so apologies for it being asking questions.
I have classic ABS light on after moving fault.
I used Sysgen's method using a multimeter to check the four sensors.
3 are reading the same (0984) the last one reads slightly less (0956).
Would this be where my problem is coming from or would there have to be more of a difference in resistance for it to be an issue?
Old 04-20-2012, 10:31 AM
Sysgen
Sysgen's Avatar
Welcome aboard, please specify where you are from in your profile, it's always nice to see.
I don't personalty think this small difference would make any difference. It's too small. Maybe if it was half.
Next step is to swap the ABS unit. I think I have one, would let it go for $50+shipping if you want it.
Let me know.
Old 04-20-2012, 10:38 AM
liveinadive1
5th Gear
Cheers for the quick reply Sysgen.
Have updated my details as you suggested.
OK cool, next step control unit.
Thanks for the offer but being in the UK after shipping it might work out quite espensive.
Old 04-20-2012, 10:41 AM
Sysgen
Sysgen's Avatar
Indeed, shipping would be a killer
Good luck.
Old 04-20-2012, 11:41 AM
gregeast
gregeast's Avatar
I had similar issues: '!' on after driving and all the sensors had similar ohm readings. In my case the car had been in an accident and so I knew which corner to start at so I bought a used sensor fairly cheaply and it fixed the problem.
I do vaguely recall that the failed sensor looked different than the new (used) replacement, the magnet (or whatever that is) that protrudes appeared to be shorter on the bad sensor but it still had the same ohm reading as the others.
Quick Reply: ABS Problem Resolved.
