996 Forum 1999-2005
Loud window squeaks when rolling down...
Old 06-20-2006, 02:25 PM
rmcgookey
rmcgookey's Avatar
Default Loud window squeaks when rolling down...
I’m getting a loud squeak when I roll down the drivers side window. The sound is reminiscent of fingernails on a chalkboard. Makes me cringe. It doesn’t happen all the time, but on select days – I guess it depends on the humidity or other weather conditions. Anyone know how to address this problem and/or any quick fixes?
Thanks so much.
Old 06-20-2006, 03:50 PM
an02boxster
an02boxster's Avatar
I wax my windows when this starts with regular car wax. It lasts a month or so here in FL.
bowmanm98
bowmanm98's Avatar
Seriously? With what wax? On the outside or inside?
Old 06-20-2006, 04:13 PM
an02boxster
Outside. Was driving me crazy the noise and the extra load on the motors did not want ot be buying new ones. Oh yeah Zymol.
Old 06-20-2006, 05:00 PM
rmcgookey
rmcgookey's Avatar
That sounds like a good idea. I suppose i should determine if the squeak noise is coming from the window's pressure against the inside weather strip or the outside first though.
Old 06-20-2006, 05:01 PM
bowmanm98
bowmanm98's Avatar
oh really, so it's the strain on the motor that's causing the noise? Hmmmmmm very interesting. Thanks for that. Knowledge sharing is so awesome.
Old 06-20-2006, 06:10 PM
gota911
Newbies Hospitality Director
gota911's Avatar
No, it is not the strain on the motor that causes the squeaking. I think he meant that when the humigity is low, there is a limited amount of moisture to "lubricate" the window and/or the weather stripping, which results in the squeaking of the window as it moves against the dry weather stripping. This happens to my car occasionally, too.
Old 06-20-2006, 06:33 PM
bowmanm98
bowmanm98's Avatar
Oh mine sounds more like a grinding noise it must be something different.
Old 06-21-2006, 10:37 AM
an02boxster
bowman I would still try the wax I will make it easier on the motor and mechanism.
Old 06-21-2006, 11:08 AM
rmcgookey
rmcgookey's Avatar
Yes, what i meant was the sound was coming from the friction from the window and weather striping, not fromt he motor itself. I will try the Zymol wax method. Thanks for the advice guys.
Old 06-22-2006, 11:21 AM
jb26jb
jb26jb's Avatar
If you have a grinding noise it may be your window regulator that's going. Waxing window should help squeeling but I just use a little vinyl/rubber protectant like 303 on the outside piece of trim seems to work for months.
Old 06-22-2006, 05:44 PM
Scouser
Scouser's Avatar
Mine did that after I Rejex'ed the windows. Not at all dissing Rejex, anyone will tell you I love this product. But it causes my windows to screetch when winding. After I cleaned them down with fairy liquid then viniger they dont sqieak any more.
Old 06-22-2006, 06:53 PM
gota911
gota911's Avatar
Scouser - I know you are in England and "American English" is slightly different from "the King's English" but what the hell is "fairy liquid?" I hate to even tell you what I "think" it is!
Quick Reply: Loud window squeaks when rolling down...
