964 Forum 1989-1994
No power to cigarette lighter, wiring diagram?
Old 10-01-2006, 02:40 AM
TR6
TR6's Avatar
Default No power to cigarette lighter, wiring diagram?
I just tried to plug my radar detector in to my 12v cigarette lighter for the first time since I bought the car and found that the outlet has no power. Does anyone have or can point me to a wiring diagram that shows that circuit? Any suggestions on what to check or how to get to the backside of it? -thanks!
Old 10-01-2006, 04:29 AM
DaveK
DaveK's Avatar
Are you sure it has no power? Mine definitely is getting power - but it takes me about 20 minutes to twist the plug "just so" so that it works. The socket itself needs a bit of work on mine.
Old 10-01-2006, 09:22 AM
jimq
Burgled
jimq's Avatar
There is no easy way to get the plug back on the back of the socket if it comes off!
Old 10-01-2006, 01:21 PM
MarkD
MarkD's Avatar
I second jimq's comment.
I had the same problem and had a really fun time getting the wire plugged back in.
Here is my previous post on this: https://rennlist.com/forums/showthre...ferrerid=35947
Read that entire thread (4 posts I think). it also has a link to another.
Kind of sums up the whole issue.
I assume you checked the fuse, of course.
Also, the socket has a different ID than most US cars. They make a thin sleeve that acts as an adapter to address the problem DaveK mentions above.
Good luck sir!
Quick Reply: No power to cigarette lighter, wiring diagram?
