911 Forum 1964-1989
SPEEDOMETER SENDING UNIT BAD?
Old 10-10-2006, 04:21 PM
Dr.Chris
Dr.Chris's Avatar
Default SPEEDOMETER SENDING UNIT BAD?
Can anyone explain how to find,where to find, and how to change the speedo sending unit on a 1988 911? I know it is on the left side of the tranny but do I put it on a rack or just use a jack etc. Pics would be a big help. The part is only $75, so unless it is a job best left to the pros I would like to give it a try. Thanks
Old 08-10-2011, 10:53 PM
pojefferson
pojefferson's Avatar
did you ever get a response (outside of this thread)? I have an '88 911 with bad sending unit magnets.
Old 08-10-2011, 11:25 PM
ivangene
Parts Specialist
ivangene's Avatar
Seriously this is 5 YEARS old
Old 08-11-2011, 01:05 AM
88911coupe
88911coupe's Avatar
OK, maybe this will help someone with this problem. I have an '88 and beat my head against a wall trying to figure out why my speedo stopped. It checked out fine but would not work even with a NEW sending unit. Turns out on my particular car I have FOUR, not eight, magnets on the little aluminum wheel inside the tranny. On top of this, the sending unit only works if you insert it about halfway in the hole on the driver side of the tranny. I found this out by accident and had to fabricate something from an old piece of heater tube that would keep the sensor only partially inserted. I s/w the tech at Pelican Parts who confirmed there was only one part for my car...no mid year changes.
Old 08-11-2011, 08:58 AM
pojefferson
what's your point. There will be 1988 Carreras w/ speedometer problems in another 5 years.
Old 08-13-2011, 10:22 AM
jm58
5th Gear
jm58's Avatar
I didn't know that it exists 4 points magnets disk... why did you change it at the beginnings of your speed. trouble? Did you find the reason why it didn't work such as magnets missing or sensor broken ? I figure out why mine doesn't work too because it did work one time last month during 15 kilometers then not anymore....so I also beat my head against a wall to try to find the root of that problem.
Thanks for help
JM
Old 08-15-2011, 01:19 AM
88911coupe
88911coupe's Avatar
Mine stopped working suddenly and I assumed it was the speedo itself. Sent the speedo to a company in Austin and they confirmed it was working fine. I started digging around and then decided to order the new sending unit since I did not really know what else to try. After I installed it I noticed it was not working and was tinkering around trying to see what the problem was. That's when I determined I only had 4 magnets and also that the sending unit only worked when it was inserted about halfway into the mounting hole. If it goes all the way in it appears it's just "past" the magnets and does not work.
Old 08-17-2011, 01:48 PM
jm58
5th Gear
jm58's Avatar
Thanks for help 88911 ,I will try to withdraw a little bit the sensor to check if mine has not the same problem...
Cheers
JM
Quick Reply: SPEEDOMETER SENDING UNIT BAD?
