996 GT2/GT3 Forum 1999-2005
GT3 Motor mounts
Old 04-16-2007, 12:20 AM
  #31
iLLM3
iLLM3's Avatar
Originally Posted by RayGT3
The "esses" at the Glen are arguablly the fastest ( I'm guessing 150 - 165 mph not really looking at that point) part of the track. They are long sweeping high speed uphill turns. The fastest way around is to carry as much speed as possible through turn one and bury the throttle through the esses. This gives the engine pleanty of opportunity to rock back and forth as you transition from one sweeper to the other. One thing you really don't need is 500 lbs shifting around behind you in this type of situation. So as others have stated, if you might have issues, this is where it will show up, a really good test.
Wow very interesting.. There was big motor mount discussion on 6speed, and i heard part of the feel of the GT3/GT2 compared to the 996TT's were due to the Motor mounts, are they in fact different at all??
Old 04-16-2007, 10:47 AM
  #32
RayGT3
RayGT3's Avatar
As far as I could tell the motor mount P/N's used in all the '04 996's are the same. If you look at the pet the P/N's are supposedly different. Not sure what all that means, but my GT3 had the same P/N mounts as my friends C2. I have heard some discussion about different color paint being applied to indicate differences, don't know anything about that. Mine had just a yellow sticker with a production date on it. If there might be any question as to which ones are in a car it's pretty easy to tell, just open the deck and look, they are right there and easy to see P/N's.
Oh, and Ed, I apologise for insulting your sensibilities. What I meant by the comment relative to speed in the esses was relative to max speed attained. Not speed maintained "through" them. I am able to do about 140 before the bus stop and was not by any means the fastest car there, so guessed 150 or better, would not be out of the question for some. No smoke here, just a comment. Lighten up.
Old 04-03-2012, 11:05 AM
  #33
gman3280
gman3280's Avatar
Reviving an old thread through the search feature! Who says no one uses it…
I’m planning on putting in new motor mounts on my 60K mile car. It will see 85% daily driver and 15% track time. Which motor mounts are the current recommended version? Also, if it matters I’m going to change the trans mount with the 997 version from Suncoast. As I see it I have four motor mount options:
993-375-049-08 Carrera / 4 - $91.50 each from Pelican Parts
993-375-049-08 Turbo - $92.00 each from Pelican Parts
964-375-043-81 Euro RS Mounts - $185.25 plus the new bolts and washers – Pelican Parts
Wevo mounts – $198.75 direct from Wevo
Thoughts?
Old 04-03-2012, 11:43 AM
  #34
911SLOW
Admin
911SLOW's Avatar
Can't go wrong with the RS mounts. Perfectly drivable on the street.
Good call on the tranny mounts.
Old 04-03-2012, 12:00 PM
  #35
gman3280
gman3280's Avatar
Ouch, just totaled up the washers / bolts for the RS mounts and it adds about $100 to the cost.
Old 04-03-2012, 12:32 PM
  #36
996FLT6
996FLT6's Avatar
Hey John can the rubber insert inside the Rs mount replaceable and can be bought separately? Rennline has a nice semi solid mount and the rubber insert is replaceable. Costs abit more- I think it's $400 but looks nice. I have RS mounts on mine- no problema on the street. Mike
Old 04-03-2012, 12:33 PM
  #37
996FLT6
996FLT6's Avatar
Oops sorry wevo not rennline. Mike
Old 04-04-2012, 10:03 PM
  #38
rodneyr
rodneyr's Avatar
Interesting discussion. I have the Wevo mounts in my car. I probably got them too early when I was learning the car to know the difference from the stock mounts.
As for the Glen, the biggest confidence booster for me was the RS Wing. It really make the car feel more planted/stable going up the esses. The speedo looks like 150+ but the Traqmate tells the real story. I know I am not at 150 and the wing at 8 degrees and my ability do slow down the terminal top speed.
At the end of the day, the wing, spliter, mounts, etc aid in the mechnical process but it takes a lot of confidence to actually lower lap times.
Old 04-05-2012, 01:03 PM
  #39
bobsan
bobsan's Avatar
Wevo, though I suspect RS are just as good, however you can change the bushes in the Wevo if they wear, or want another stiffness.
Plus Wevo's are very light and look half decent.
Old 04-05-2012, 01:17 PM
  #40
HiWind
HiWind's Avatar
Wevo look very solid and nice that you can maintain them. Do they make the gearbox mounts too?
Old 04-05-2012, 10:25 PM
  #41
MTB
MTB's Avatar
I checked with Wevo, no tranny mount for Gt3. Erik@Gbox and torque solution do make the mount.
No one makes bushing replacement! There is DIY filling the gaps with urethane. Cheap way to make the mount stiffer.
M
Old 04-08-2012, 05:51 PM
  #42
HiWind
HiWind's Avatar
Thanks MTB - what are you running on your (appears to be RS cloned) 996GT3? I understood wevo made the replacement bushings. I also understand some further down the slippery slope people run the 964/993 RS mounts which are semi solid and lighter ... But need longer bolts.
Old 04-08-2012, 09:34 PM
  #43
MTB
MTB's Avatar
She just a GT3 with RS wing. I have RS engine mounts and you are correct, it needs longer bolts. The tranny mount still OEM. Since I have RS engine mounts, I think it will be a good idea to have a stiffer tranny mount. Will drop engine for coolant fittings fix in May. If the tranny mount still in good shape, I will stiffer it by filling the gaps with window weld.
File Type: pdf
Old 04-08-2012, 11:02 PM
  #44
cfjan
cfjan's Avatar
Do you have links for any of the tranny mounts you mentioned?
M
Old 04-08-2012, 11:35 PM
  #45
MTB
MTB's Avatar
http://www.torquesolution.com/product-p/ts-por-006.htm
See post #21 for mount from Erik@Gbox
http://www.6speedonline.com/forums/9...-insert-2.html
FYI
Quick Reply: GT3 Motor mounts
