993 Forum 1995-1998
Front License Plate
Old 10-31-2007, 11:58 AM
WHB Porsche
I'm Still Jenny
WHB Porsche's Avatar
Default Front License Plate
Are the screws that hold the mounting frame self-tapping or does the bumper (it's a Turbo bumper) have to be removed for the frame to be attached? How does one get those little screw-hole-filling nubs out of the front bumper?
Thanks in advance,
Charlie
Old 10-31-2007, 12:03 PM
MarkD
MarkD's Avatar
Thanks in advance,
Charlie
The first project on the TT eh? Good one to start with!
Those little plastic things have to be pried out carefully. It has four prongs that expand outward when pushed into the bumper. A small screwdriver will do it... be patient. Use a backing material to protect the bumper from the screwdriver. If you get a very small screwdriver you can get it inside the plastic nut and snag one of the prongs to pry it inward.
Then visit bumperplugs.com (RL sponsor) and get a color-matched set to fill those holes.
You might want to put a dab of black silicone on the back of the bumperplug when you insert it. They can tend to slide out or get caught on a wash mitt or towel.
Have fun!
EDIT: Wait, are you adding a plate? or deleting it?
If adding, it sounds like maybe there are bumper plugs in it now. You will need the little white plastic snap-in nuts.
The bumper plugs would just pull out.
Old 10-31-2007, 12:07 PM
WHB Porsche
I'm Still Jenny
Oh, I should clarify. I want to put the front license plate bracket ON. The car has matching bumper plugs already, which I need to get OUT. The friendly local NYPD doesn't have a sense of humor regarding front plates.
Old 10-31-2007, 12:09 PM
MarkD
MarkD's Avatar
OK, see above.
The plugs just pull out.
The plastic nuts that pop in can be bought just about anywhere.
Old 10-31-2007, 12:26 PM
WHB Porsche
I'm Still Jenny
Cool, thanks. I'm a bit confused, it's been a hectic day. I'm the only one on this board crazy enough to put the front plate back on.
Old 10-31-2007, 12:41 PM
IamSMC
IamSMC's Avatar
http://www.bumperplugs.com/
Old 10-31-2007, 01:06 PM
Greg H.
Greg H.'s Avatar
WHB -
Do a search as there is an option for mounting the plate in front of the opening below that looks a lot cleaner. I think someone is selling a kit to do it, or you can easily make one yourself once you understand what his kit does.
Greg H.
Old 10-31-2007, 01:56 PM
fullbooker
fullbooker's Avatar
I got a fix-it ticket in California a while back for my European style plate. I simply drilled two holes in the California license plate and mounted with sheet metal screws directly into the bumper plugs/clips. Went to CHP office to get the ticket signed-off and officer didn't even look at car. Went home and removed plate, stored it in trunk for later "use." Can put it back on if needed in about a minute.
Old 10-31-2007, 02:42 PM
David in LA
David in LA's Avatar
Originally Posted by Greg H.
WHB -
Greg H.
www.inventivaconcepts.com I have one that I am hoping to install one day when I have time...
Old 10-31-2007, 03:07 PM
dbf73
Boost Junkie
dbf73's Avatar
+1 on the Inventiva plate bracket (and their cup holder too) - looks tons better than the factory version
Old 10-31-2007, 04:26 PM
Dudley
Dudley's Avatar
Here is mine with the Inventiva plate bracket.
Old 11-01-2007, 11:35 AM
ientre9y11
ientre9y11's Avatar
I have the Inventiva bracket. Looks way better than the stock system, especially when you get the matching bumper plugs.
Old 11-01-2007, 07:57 PM
ed devinney
ed devinney's Avatar
Another vote for the inventiva bracket if you want a plug & play, it appears to be a nicely made product with all the bits you need to do the job. It's an easy DIY if you want to try, I made one in well under an hour: http://homepage.mac.com/ejd . An update, I've had mine up to 120mph at the track, still no issues :-)
Old 11-01-2007, 08:16 PM
WHB Porsche
I'm Still Jenny
Well, I've got the factory plate mount on it now, as I didn't really have time to wait for the Inventiva one and I'm not sure I'd like to drill into the bumper, for now at least.
Old 11-01-2007, 08:20 PM
Land Jet
Land Jet's Avatar
Anyone have the web site link to the place that makes the licence holder that attaches to the tow hook hole?
Quick Reply: Front License Plate
