Identifying Durametric software fault codes?
Old 02-26-2008, 06:21 PM
WaltB
WaltB's Avatar
Default Identifying Durametric software fault codes?
I just ran the Durametric software on my 06 997 C4S and got the following faults:
Airbag: C152 Meldung timeout PSM
PAS: 8004 Versorgungsspannung Klemme 50 (SC+)
Does anyone know what these mean and is there a list of fault codes I can get?
Thanks in advance.
Old 02-26-2008, 08:21 PM
jayster
jayster's Avatar
Didnt know Durham did it in German...
Old 02-26-2008, 09:49 PM
Deanski
Deanski's Avatar
Have you contacted Durametric on these? I'm sure they have a way to convert the display from German to English language.
Deanski
Old 02-26-2008, 10:19 PM
hjacobs2000
hjacobs2000's Avatar
Update your software version
Old 02-26-2008, 10:26 PM
WaltB
WaltB's Avatar
It is the latest version and I selected English. Airbag in English.
Not sure what PAS is
Old 02-27-2008, 11:16 PM
Deanski
Deanski's Avatar
What has Durametric have to say about these issues?
You may have the latest software, but obviously, there is some issue which they need to be aware of.
Deanski
Old 02-28-2008, 12:01 PM
Coochas
Coochas's Avatar
Shouldn't be errors in German. Do you by chance have German set as your PCM language?
If you join Renntech.org you'll have access to Porsche error codes; however, I've had a few error codes come up with Durametric that I could not find on Renntech's database! The car runs perfectly and there were no flags at my recent 2-year service at Ira (although they would not provide me with a DME printout).
Old 02-28-2008, 12:59 PM
Edgy01
Poseur
Edgy01's Avatar
Versorgungsspannung is supply voltage.
Old 02-28-2008, 01:20 PM
WaltB
WaltB's Avatar
I'm waiting a reply from Durametric. In the meantime, what is the URL to Renntech?
Thanks
Old 02-28-2008, 02:24 PM
jayster
jayster's Avatar
Did your battery die lately? Reset it and see if the code comes back...
Old 02-28-2008, 02:33 PM
wross996tt
wross996tt's Avatar
Thanks
Renntech.org
Old 02-28-2008, 04:37 PM
WaltB
WaltB's Avatar
Just received this from Durametric,
I Had PSE installed by the local Porsce dealer and I know they did disconnect the battery so that is probable the cause of these. I will reset them and monitor. Thanks everyone who responded.
The software is capable of displaying approximately 8500 fault codes, and there are about 8250 in English so some faults will default to German when the English description is not available. Most of these are for the 997 as these being new the documentation from Porsche comes out first in German.
Both of these faults are in German.
This fault means “Supply voltage at terminal 50” this was probably caused by a disconnected battery.
And
“Communications timeout with PSM”, another fault that is normally caused by disconnecting the battery.
I have added both of these to the English list so the next release will include the updated descriptions.
Best Regards,
Duram
Durametric Software
Quick Reply: Identifying Durametric software fault codes?
