964 Forum 1989-1994
Oil overfill causing smoke?
Old 08-08-2008, 09:55 AM
carby
carby's Avatar
Default Oil overfill causing smoke?
Blahdy workshop (in Melbourne, who shall not be named) overfilled the bugger they did. Now I got dem schmokies!
Old 08-08-2008, 10:17 AM
elbeee964
elbeee964's Avatar
"I love the smell of napalm in the morning. That smell, you know, that oil smell. Smells like... an oil overfill."
- Lt. Col. "Wild" Bill Kilgore
Dropping oil to lower levels (checked against running-engine readings of the dipstick) sounds like you're on the right track.
(Premature to assume valve guides, IMO, till that's done.)
Good luck, trooper.
Old 08-08-2008, 03:35 PM
Indycam
Indycam's Avatar
An oil over fill causes smoke .
Been there done that , aint going back .
The extra oil goes into the intake system via the oil tank vent .
When the dry sump pump picks up oil and air , it pumps it into the oil tank , the air / blowby is sent into the intake system via a tube . If you overfill the oil tank , the oil goes out that very same tube and gets sent right into your cylinders .
If your cars running ok , take it out for a real nice long drive to burn off the oil thats gotten into your cylinders and exhaust .
Old 08-08-2008, 07:14 PM
carby
carby's Avatar
Such a simple mistake...its a wonder Porsche didnt design a failsafe for such an oversight.
Old 08-09-2008, 01:29 AM
Indycam
Indycam's Avatar
You can put a catch can in the overflow / vent line if you think you will be overfilling the oil again .
Old 08-09-2008, 02:44 AM
carby
carby's Avatar
So I've sucked a liter out of the filler neck when it was nice and hot, went for a quick blast....seems to have worked.
Old 08-09-2008, 09:39 AM
jim_l
jim_l's Avatar
do you guys think that adding oil while the engine is running could backup into the overflow and cause the white smoke?
Old 08-09-2008, 10:20 AM
Carl Muckenhirn
Carl Muckenhirn's Avatar
Default I always refill while the engine is running.
Lets you check the level.
The overfull vent is in the tank, not the filler tube so there's no risk (or we'd all have oil in our intakes).
c.
Old 08-09-2008, 11:28 AM
elbeee964
elbeee964's Avatar
Sorry -- we all do.
(Just for most, not to the point of mosquito suppression.)
But I take your point.
Old 08-09-2008, 12:20 PM
Lancaster911
Lancaster911's Avatar
Hey everyone forgot something!!!
Grats on your first 911!!!!!!
Old 08-10-2008, 12:10 AM
carby
carby's Avatar
Many thanks, has been a joy and a steep learning experience so far.
c
Quick Reply: Oil overfill causing smoke?
