Flat crankshaft
Old 06-30-2009, 09:06 AM
puyi
puyi's Avatar
Default Flat crankshaft
Hi all,
Is there someone who provided at any time flat crankshaft for the 928 and related camshaft?
Thank's for all
Puyi
Old 06-30-2009, 09:13 AM
slate blue
slate blue's Avatar
Not that I am aware, there would be a lot of potential development issues especially with vibration. No real advantage either.
Greg
Old 06-30-2009, 09:16 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
It would be cheaper to drop in a Ferrari V8 from the get go.
355 motors appear to be going for about $10,000.
Old 06-30-2009, 09:29 AM
Mike Frye
Craic Head
Mike Frye's Avatar
OK, totally had to look this one up. I'd never even heard of it, but this website has a very cool write-up on the difference between flat plane cranks and cross plane cranks (for those of you following at home like me).
Old 06-30-2009, 09:35 AM
ptuomov
ptuomov's Avatar
Get (i.e., make) cross-over headers instead! Way cheaper and with almost all the benefits.
Old 06-30-2009, 09:46 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
There was a long thread discussing the pros and cons of this idea a year or two ago. I tried searching but I cannot find it.
Old 06-30-2009, 10:00 AM
123quattro
123quattro's Avatar
Except that the primary lengths would be way too long.
Old 06-30-2009, 10:15 AM
ptuomov
ptuomov's Avatar
Not really, since 928's gearbox is far in the back. The long runners can have a narrow resonance tuning rpm range, so the exact length of long runners is important. Scavenging should be excellent with the pulses matched.
Old 06-30-2009, 11:25 AM
hans14914
hans14914's Avatar
Didn't Tom Cloutier "The Power Broker" make a set of headers for this specific purpose several years back? I believe he was crossing the primarys across to achieve the exhaust scavenging and tone associated with the flat crank. Now that I think of it, I think he called it The Scavenger or something like that.
BTW, here is the old thread on flat-plane cranks:
https://rennlist.com/forums/928-foru...28-engine.html
Old 06-30-2009, 11:40 AM
hans14914
hans14914's Avatar
Well, this got me thinking, and I dont have any pics saved of the Scavanger, and Tom's website www.thepowerbroker.net is gone, but I was able find this text written by Tom about his Scavanger system and how it applies the concept of a flat-plane crank to the standard cross-plane of the 928:
http://members.rennlist.com/pirtle/zexh_science.txt
If anyone has a pic saved of the system, it would be nice if they would post it in the thread, as it was a true work of art.
Old 06-30-2009, 12:02 PM
Jim M.
Jim M.'s Avatar
Tom Cloutier's exhaust headers.
Old 06-30-2009, 12:25 PM
deutschmick
deutschmick's Avatar
Mike Frye
Thanks for the link; I never really understood the difference between cross and flat-plane cranks.
Now I do!
Old 06-30-2009, 01:25 PM
puyi
puyi's Avatar
I will read the other "flat plane crank" thread. But for a race car, the pros for that is :
Cost
Reliability
weight
A+
Puyi
Old 06-30-2009, 02:38 PM
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Great write up by Tom Coultier. He references many reasons why crossover pipes scavenge better but he does say this is best applied to engines with a lot of valve overlap. Then he goes on to say the S4 engine, for example, has little overlap.
There are no before/after dyno comparisions on a 928 engine so it is hard to know just what sort of performance gain can be realized by one of these systems.
Has anyone here built/put on one of these corssover systems and also have dyno charts as comparision? I am interested in this.
Old 06-30-2009, 03:32 PM
Ben Allison
Ben Allison's Avatar
If the crankshaft could be made cheaply enough (hah hah), you could have a killer cheap upgrade for the 2 valve cars. 100mm 944 2valve pistons ALMOST work in the 928s but are 2mm too short. Increase the stroke by the correct amount on the Flat Plane crank to compensate. Use 944 camshafts on the existing 928 heads with the larger 944 valves.
On the same note, custom ~2mm longer rods would accomplish the same job with stock crank.
Quick Reply: Flat crankshaft
