leather seat repair kits
Old 07-19-2009, 01:04 PM
garylane
garylane's Avatar
Default leather seat repair kits
Finally thought I'd post a few pictures and details of the leather repair and re-die from my interior. When i purchased the car it had a rather worn looking dark blue interior. The driver seat bolster had three nasty looking rips. I thought about going for a complete re-trim but the costs were horrendous. I then looked into the leather repair and re-die kits you can get on the internet. After looking at various you tube video links on the procedure I thought I'd give it a go. After taking the seats out first you rub them down with a solution that takes of the top protection layer and some of the old die. This gives the new die some thing to key on to. This was a very messy job. Then you have a special compound to repair the rips. First you lay some hessian behind the rips and glue the edges down. Next you slowly fill the rip in with the compound which is a kind of very wet putty. You slowly build it up layer by layer until it sits proud of the suffice. Next you sand it down until it's level with the suffice trying not to sand too much of the surrounding leather away. This is a very slow process and it took me many times to get to a reasonable state that I was happy with. When I was finally done with all the filling and sanding it was time for the re-die. I decided to go all out and completely change the color from dark blue to light beige . I had the firm custom match me a color of my choice. First you dab the die which is more like a very very thin paint all over with the provided sponge and leave to dry. Then you slowly build up layer after layer by spraying on the die with the hobby air gun provided. This turned out to be very slow and nearly useless. I'm lucky enough to be in possession of a compressor and spray gun so i used this instead. All though this gets the job done quicker it is much more thirsty on die. I used 5 liters to do the full interior all though i did do the dash, door cards and center console as well.. The hardest part was between the back and bolsters and seat back and cushions. I had to press down with my knee to open the gaps between cushions and bolsters and spray a little at a time, drying with a hair dryer before releasing my knee so the two parts did not touch and stick together. What a pain in the A****. I lost count of how many coats of die I sprayed but it was at least six. Finally I sprayed on a protective sealant which gives it a gloss, matt or semi matt finish. I then did the lower door cards, lower dash which I replaced because the old one was cracked and the center console. I finally replaced the whole interior back in the car while adding a new illuminated gear lever, blue illuminated leds in the instrument cluster and air con controls, some aluminum instrument bezels, a carbon fiber dash kit and a new steering wheel. The whole job took two very long days to complete I know some of you may think its too bling for their liking but I just wanted to show what could be done with £150 worth of leather repair kit as apposed to a £2000 re-trim.
Old 07-19-2009, 01:52 PM
944Ross
944Ross's Avatar
I'd be curious to see if the repairs @ rips hold together after being used.
Old 07-19-2009, 02:11 PM
garylane
garylane's Avatar
I finished about four months ago and use the car at least once a week. Apart from a little damage to one seat beading while putting it back in the car, I've had no problems. The sealant appears to be very hard wearing as long as you do it properly and since I bought loads of die and sealant, I can always re-do them. As for the rips, the putty is really elastic even when dry and I could not pull it apart. As with all leather, I suppose it will wear with regular use. I purchased the kit from here http://www.furnitureclinic.co.uk
Old 07-19-2009, 02:32 PM
JohnKoaWood
JohnKoaWood's Avatar
I've been toying with the idea of that antena for quite a while... Now I'm convinced... Beautiful car BTW..
Nice save on the interior... looks great... excellent craftsmanship... nicely done...
Old 07-19-2009, 03:50 PM
harrisonrick
Captain Obvious
harrisonrick's Avatar
Well I am IMPRESSED. Looks darn good.
Old 07-19-2009, 04:19 PM
billthe3
billthe3's Avatar
That looks really good. I've been (extremely) slowly attempting the same thing with my seats, but I accidentally watered down the dye too much and haven't been able to get full consistent coverage of the darker base color.
Old 07-19-2009, 06:27 PM
garylane
garylane's Avatar
Cheers guys thanks alot
Old 07-20-2009, 04:36 AM
garylane
garylane's Avatar
Added photos to post!
Old 07-20-2009, 04:52 AM
Po924S
Po924S's Avatar
HOLY ****! Dude that is amazing! Good job!
Old 07-20-2009, 10:37 AM
harrisonrick
Captain Obvious
Hey....what floor mats are those?
Old 07-20-2009, 02:56 PM
garylane
garylane's Avatar
Sorry not sure what floor mats are. They came with the car
Old 07-20-2009, 03:25 PM
rattlesnakeracing
rattlesnakeracing's Avatar
Talking Beautiful Job
Uuummmmm...... the steering wheel is on the wrong side??? Heh heh, only kidding!
Your 944 is beautiful to the max. Congrats on the results of the job. I'm not too hip on the carbon fiber "look". I think it is because I have a fetish and I am addicted to the smell of hot leather and the smoothness of the texture. Could be from falling asleep in my recliner too often while drooling over the quality of work like you have accomplished!
Old 07-20-2009, 03:59 PM
MAGK944
MAGK944's Avatar
Very nice work on the leather. FYI I know a number of people in the USA who have used Leatherique with good results. Looks like a very similar product with almost identical prep.
Old 07-20-2009, 04:08 PM
BlackOp
BlackOp's Avatar
Looks great! I have a question. I have very minor bolster wear and the start of cracking...could this been done in sections? Meaning, would you have to do the entire seat? Could this be done without removing them?
Where did you get the shifter ****?
Thanks,
BO
Old 07-20-2009, 04:11 PM
billthe3
billthe3's Avatar
Yeah, the stuff available from leatherique can be done in sections. You send them a patch of the material that they then color match the dye to, so you could do only a section with the seat in the car. Mind you, it has to dry for something like 48hrs before you can use the seat, so the car won't be able to go anywhere, but you can do it.
Quick Reply: leather seat repair kits
