Official ipod adapter from porsche.
Old 11-10-2009, 12:02 AM
MyEmily
MyEmily's Avatar
Default Official ipod adapter from porsche.
Was reading the latest issue of Christophorus and it indicated there is a new gadget for the ipod that fit all 997,
http://www.porsche.com/all/media/fla...index.htm#/36/
finally, porsche see the need. Anybody here know the price?
Old 11-10-2009, 01:57 AM
ADias
ADias's Avatar
It's an option for 997.2s with the new PCM.
Old 11-10-2009, 02:24 AM
MyEmily
MyEmily's Avatar
The write up on Christophorus stated it will adapt to CDR 23 AND CDR 24 and older Porsche model. Can be placed within glove compartment or center console. From 356 through all 911 models (Type 997) as well as the first generations of boxster type 987 and caymen.
Old 11-10-2009, 02:51 AM
OldGuy
OldGuy's Avatar
My iPod works great in the car.
Old 11-10-2009, 08:47 AM
sws1
sws1's Avatar
That link is for the FM transmitter.
Old 11-10-2009, 11:21 AM
prwdmd
prwdmd's Avatar
It says that it connects via PCM... the description does not mention a radio link as they had on the previous ipod solution. Maybe this is their new ipod interface. If so... I will definitely be getting this. Did the Christophorus article say this was a direct connection to the PCM?
Old 11-10-2009, 11:58 AM
rvklein
rvklein's Avatar
Says control through the PCM. That wouldn't be an FM transmitter.
Old 11-10-2009, 12:36 PM
Trader220
Trader220's Avatar
the retro for ipod on 997.2 with PCM 3.0 has been out for a long time
Old 11-10-2009, 01:45 PM
akim47
akim47's Avatar
i think the link is for 997.1 stuff... and it says "to 7/2008"... am I missing something?
Old 11-10-2009, 02:10 PM
Edgy01
Poseur
Edgy01's Avatar
This is a retrofit kit for the 997.1 owners. Via the MOST ring.
Old 11-10-2009, 02:13 PM
Ucube
Ucube's Avatar
The link specifically says it's for 997.1, although it also says the operations are via the music player. That sounds to me like you can't control the iPod via the PCM.
Old 11-10-2009, 02:14 PM
stevebmd
stevebmd's Avatar
Dont get excited folks, that is the porsche FM transmitter...it says operation is through music player...meaning ipod or what ever music player is plugged in. It will charge via the 12v power point in the console, BUT there is no MOST connection, hence its compatiblity with CDR units and PCM2.0
Old 11-10-2009, 03:18 PM
stevepow
stevepow's Avatar
That Technik catalog doesn't seem new - so, is this really the same thing mentioned in the C mag?
Old 11-10-2009, 04:00 PM
MyEmily
MyEmily's Avatar
Don't know if its new or not. That's why I throw it out for discussion and hopefully, a porsche tech guy will know. From the article, it stated the connection is through PCM. But it didn't state control by it. If it doesn't control by PCM, it's basically a Aux passthrough. Having an option of placing in the glove compartment puzzled me. If control by the Ipod, how can it be control?
If it's controlled by the PCM, wouldn't mind look into it unless it.
Old 11-10-2009, 05:45 PM
J.R. de Veer
4th Gear
J.R. de Veer's Avatar
What you're actually looking to do is have your IPOD work through your current PCM and existing stereo system, without the use of a FM transmitter, correct? If so, you can order the DICE integration kit from BumperPlugs.com. The product is Dension IceLink Gateway 500 and it costs $479. Hope this was helpful.
Quick Reply: Official ipod adapter from porsche.
