Home Made MAF
Old 12-14-2009, 09:48 PM
spyder348
spyder348's Avatar
Default Home Made MAF
Anyone have any pics or info. about how to set up a MAF with custom pipe and sensor from another car?
Old 12-14-2009, 10:05 PM
alxdgr8
alxdgr8's Avatar
Any sensor can be made to work, so long as you know the transfer function for the MAF and then create some genuine MAF code for the DME. Don't be fooled by the thread talking about using a Ford Countour MAF (or whatever it was) by just plugging it in...not going to work "correctly". Many of the aftermarket MAF setups uses translators that go in between the MAF sensor and the DME. These "modify" the MAF sensor signal into looking like an AFM signal that the DME can understand. If you want a true MAF setup there is a lot of work involved and not something for the average DIY...hence why there are only a few people that have ever doen this (Vitesse Racing for example).
Lots of info on MAF setups, use the search and you'll find thread after thread about it.
Old 12-14-2009, 10:26 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
spyder,
Check out these threads - I explain the aforementioned issues:
Thread 1
Thread 2
-Rogue
Old 12-14-2009, 11:04 PM
gt37vgt
gt37vgt's Avatar
i found running 2 AFM in series (old and new )a good way to log and and compare out puts of the AFM's to get the initial set up data .
Old 12-14-2009, 11:27 PM
pormgb
pormgb's Avatar
I'm running an 80mm Mustang Cobra MAF with Lindsey Mafterburner.
Old 12-15-2009, 12:24 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...d=390122396648
Injectors
Chip/Piggy back
= done and done.
Old 12-15-2009, 12:31 PM
951_RS
951_RS's Avatar
Interesting todd, how did you get that to work and with what piggy back
Old 12-15-2009, 12:48 PM
95ONE
95ONE's Avatar
Originally Posted by toddk911
ebaymotors
Injectors
Chip/Piggy back
= done and done.
I bought the exact same MAF once upon a time. I was going to buy a chip and piggy back from Lindsey, but the cost for the two came out to the same as buying just a chip programmed for my set up by Vitesse. Idle was flawless. Airfuel was perfect. Just never worked out as it should have due to my - Unknown at the time - Fried Dash harness feeding the wrong voltage to the ECU. Seriously frustrating part of my 951 history. Anything past 3K rpms got all screwed up. BEFORE the MAF and chip change, and after.
I still suggest the same to anyone with a currently working harness. lol
Old 12-15-2009, 01:36 PM
carlege
carlege's Avatar
Suggest the "same" what is the same?
Old 12-15-2009, 01:37 PM
V2Rocket
Rainman
V2Rocket's Avatar
i have a contour maf wired up for a 944 afm plug and ready to go if you want for $60, youll need the software change to make it work properly though.
Old 12-15-2009, 03:05 PM
alxdgr8
alxdgr8's Avatar
Please don't try and sell the poor guy something that doesn't work.
Old 12-15-2009, 03:08 PM
V2Rocket
Rainman
V2Rocket's Avatar
edited lol
Old 12-15-2009, 03:33 PM
carlege
carlege's Avatar
LOL Im not going to buy that.... If its not worth keeping on your car why would i want it on mine
Old 12-15-2009, 03:46 PM
V2Rocket
Rainman
V2Rocket's Avatar
i never used it on my car as i dont have a late computer to use it with lol
Old 12-15-2009, 03:53 PM
Rogue_Ant
Rogue_Ant's Avatar
The Contour MAF might be ok for the NA, but it is not going to flow enough for the turbo guys.
-Rogue
Quick Reply: Home Made MAF
