Algae growth inside Cool Suit?
Old 06-07-2010, 03:41 PM
dp35
dp35's Avatar
Default Algae growth inside Cool Suit?
I've only had a cool suit for a few months, and should've done something about this sooner, but... My cool suit quit working last time out, and upon inspection it seems to have some blockage in the lines. I blew compressed air through them, which seems to have fixed it for now.
In the future, I need to do something to prevent things from growing inside the lines. I have a swimming pool, and for now I'm using that water in the cool suit, which should help. But when I add ice, that will replace the pool water with tap water.
I suspect there's a chemical I could add from time to time to maintain the insides of the cool suit. But what would that be? Chlorine? Vinegar?
Old 06-07-2010, 03:48 PM
paradisenb
paradisenb's Avatar
I run Isotropic Alcohol through mine at the end of each event. Prevents growth. I don't recommend chlorine bleach. If any leaks out it will ruin your seats, shirt, suite or whatever it touches.
Old 06-07-2010, 03:59 PM
DanR
DanR's Avatar
a cap full of bleech in a gallon of water run through the cool suit pump works great!
Old 06-07-2010, 04:01 PM
krystar
krystar's Avatar
water wetter...although it's supposed to smell.
antifreeze...although it's toxic...
bleach def works at killing algae...and anything it touches.
i've heard of water decontamination tablets sold at camping section. or water treatment tablets for hot tubs .
Old 06-07-2010, 04:10 PM
onefastviking
onefastviking's Avatar
The easy answer ...... use what is made to do what you are asking.
http://www.coolshirt.net/maintenance-additive.html
Old 06-07-2010, 04:12 PM
Mark in Baltimore
Mark in Baltimore's Avatar
+1.
Bleach works fine if your seats, suit and gloves are all-white.
onefastviking
A waterbed supply store also has what you need. As well, I have alwasy run a little alcohol (like a couple ounces with the rest water) in my systems when being used and then do the splash of beach (capful) and water to clean out before and after using. All of those ways have worked just fine for me.
Old 06-07-2010, 04:30 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Whew. I thought that you were talking about algae growth inside the shirt and was looking for a better deodorant. Euwww.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 06-07-2010, 04:44 PM
ApexPerformance
ApexPerformance's Avatar
Default No bleach
Cool Shirt does not recommend using bleach to clean out the lines - the bleach can eventually deteriorate the medical tubing sewn on the shirt. Here's what they recommend:
Maintenance
1) COOL SHIRT® : Turn the shirt inside out and wash in washing machine on the gentle cycle in warm or cold water.
2) To prevent scum buildup and algae growth, once per month or just before longterm storage, add 8 ounces of rubbing alcohol to the cooling unit with 1 gallon of water and circulate through the hose and shirt (or use their Maintenance additive). Or Drain the hose and shirt with the Universal Connector & Drain kit (Part# UK1).
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
Old 06-07-2010, 05:14 PM
Paul 996
Paul 996's Avatar
So the maintenance additive contains not only a fungicide (butyl cellosolve aka the blue stuff in windex) but also something that lubricates the pump.
Old 06-07-2010, 06:40 PM
magnetic1
magnetic1's Avatar
Using RODI water or water free of phosphorus will help also. Algae is growing because it has nutrients. Those nutrients are rich in tap water....
^^^ at least with my fish tank
Old 06-07-2010, 06:58 PM
TheOtherEric
TheOtherEric's Avatar
Bleach is really bad for plastic tubing except for very short contact. If you don't believe me, just toss some plastic tubing in a bucket of bleach water for a day and see how it looks.
Stick with what they recommend.
Old 06-08-2010, 12:07 AM
kristap
kristap's Avatar
My shirt is 3+ years old with nothing on the inside of the hoses; I just ran alcohol through it at the end of the year for last 3 seasons. Simple, cheap, works.
Old 06-08-2010, 08:02 AM
tsheehan
tsheehan's Avatar
I save my empty shock bags from the pool. Even empty they keep the water pump and shirts clear. I have been doing it for years. Since I burn leaded gas ,I feel like this is my green contribution to mother earth. I just put a empty bag in before the Ice and it keeps it fresh as a day in may for the weekend. If you blow out the shirts before long term storage that will also keep them from getting furry.
Regards
TSheehan
Old 06-08-2010, 04:32 PM
todinlaw
todinlaw's Avatar
You guy got some good ideas on how to clean out your pipes.
Quick Reply: Algae growth inside Cool Suit?
