Engine oil flow diagram
I've seen it a million times but I've done multiple searches & can't find it. Does anyone have the engine oil flow diagram showing the route of the oil through the engine?
TIA, Hammer
TIA, Hammer
Archive Gatekeeper
This one?
EDIT: Too slow on the draw.....
Craic Head
Seriously, is this place great or what?
I'm on other car forums and you're luck if the info to crap ratio is 1 to 4 or 5 and you usually have to wait at least a day for anything that will help.
Here? Less than 30 minutes from initial thread start to 2 WSM diagram pages posted. And they were both the right ones!
Nice work gentlemen!
James3494 (10-26-2023)
Is the oil pressure relief valve maintenance free?
Do you ever need to change the spring?
Does it sag with age, reducing oil pressure?
Can it fracture?
In my other car (Cerbera) the pressure relief valve spring fractured and a fragment found its way into the oil pump causing devastation, hence my interest
Can it fracture?
Given that Porsche kitted the car with an oil pressure gauge that goes full scale at 5 barg it would seem reasonable that they were not really interested in oil pressure above that mark. The definitive test for oil pressure is specified as a certain pressure at a specific rpm point and the numbers I have in my head are something like 4 barg at 3000 rpm on a fully warmed up motor- hopefully someone will chime in with the exact numbers.
Thus I would conclude that if you are having difficulty making such numbers investigation is clearly warranted but other than that do not be too concerned. If one were to rebuild one's motor then fitting a new spring ought to be a no brainer. Never heard of anyone routinely changing out at a given mileage but on a 30 year old motor why not?
Basic Site Sponsor
Basic Site Sponsor
Can it fracture?
Can it fracture?
The "rule of thumb", in the high performance engine world, is 10 lbs of pressure for every 1,000rpms, with the oil hot.
However, different engines do have different requirements, depending on how the oiling system is configured, how much bearing clearance is present, and how much the crankshaft flexes at different rpms. For instance, I'd be concerned if my 427 Ford steel crank "Y" block engines didn't have 100psi at 7,000 rpms.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
UKKid35 (02-10-2020)
