993 Forum 1995-1998
CDR-210 w/Ipod, Aux und USB inputs...
Old 12-22-2010, 11:54 AM
M. Schneider
M. Schneider's Avatar
Default CDR-210 w/Ipod, Aux und USB inputs...
Here's a clever interface for the CDR 210 Porsche/Becker radio units in the 993.
http://www.solisto.de/en/caraudio
I'm currently in the process of up grading the 93s OEM HiFI (POS Nokia) to that of a Dynaudio system out of a late MY07 VW EOS car with the 600w Dynaudio.
(Yeah,,, I know... what took me 12 years???) A couple of Dyn drivers mounted in the Porsche OEM HiFi positions and the Dyn/VW amp/active x-over, etc., (3C0-034-456-A) under the seat should do the trick - with no visiable modifacation.
The VW Passat Dynaudio system front speaker bucket arrangment looks like it could drop right in place behind a HiFi optioned 993 front door panel.
We'll see...
Old 12-22-2010, 12:01 PM
ilko
Agent Orange
ilko's Avatar
Hmm, I still don't see how that would work with a 210 unit. I can see it working with a 220 however.
Old 12-22-2010, 12:14 PM
M. Schneider
I'm not sure of your position? Pls clairify. The Solisto interface works like a champ with the CDR-210... charges the Iphone 3GS to boot. If your refering to the "how" of a CDR 210s speaker only output connectivity to an extenal amp.... that's easy; interface Baby..
Old 12-22-2010, 12:28 PM
ilko
Agent Orange
ilko's Avatar
You're right, my mistake. I had a different interface in mind.
Old 12-22-2010, 02:06 PM
M. Schneider
ilko - actually its been said that the early MY05 thru MY09 VW/Dynaudio authored amps/active x-overs all made by either Lear/Blaupunkt/Siemans/Etc., can broadly except both hi level and spkr level inputs - we'll see.
Old 12-22-2010, 02:07 PM
Stealth 993
Stealth 993's Avatar
Are you saying this works with the 210, for a iPhone, for music & charging?
Do you have one working, & did you order it from them?
My interface doesn't like the iPhone, it will not play music.
Old 12-22-2010, 02:23 PM
M. Schneider
Check out the firm's web site www.solisto.de for the product gamut, and yes their current version (as of mid-2009) charges the iphone 3GS given a specific in line connector to be ordered. A buddy in Frankfurt has the very arrangement is his MY97 993 mit the Porcshe CDR-21 (our CDR210) Worked fine with my Iphone 3GS.
At long last....
Old 12-22-2010, 02:53 PM
JPP
JPP's Avatar
So, on the website it quotes the box size in Millimeters at 55 wide by 24 high by 104 long. Is this unit really that small?
Old 12-22-2010, 05:27 PM
e9stibi
e9stibi's Avatar
The point for compatibility is the CD changer model. As I understand correctly, the 993s uses the CDC-3 which I have installed and it works both with C(D)R 210 and CDR220. The model number is BE 2660.
On the solisto website they say that it is compatible Silverstone 2630. However, I found a dealer website that specifically list the CDR 210 and 220 as being compatible. Just go for it and let us know ...
http://www.kolumbus24.com/default.as...m&ST=1&IT=1127
or here on the solistio website. The system should work with the limitation that it can only emulate 6 CDs with up to 100 songs each:
http://www.solisto.de/en/radios/porsche
Old 12-22-2010, 06:10 PM
M. Schneider
I too have the factory [CDC-3] CD changer as installed during production. I'll unplug one for the other.
I'd ordered the Solisto unit so we'll see; iphone 3GS as itunes. (as soon as Santa get's his sleigh on the roof)
As far as the Dynaudio upgrade goes, its a LF 110w RMS x 4, Mid-band 40w RMS x2 and HF 25w RMS x 4. D-class amplification, w/active Freq. crossover, EQ, phase alignment, impedance compensation, etc. This high end VW/Dyn amp (let VW think that - OK) coupled to the CDR-210 with a few decent quality level Dynaudio drivers placed in the 993s OE HiFi door arrangment - should sound nice. And on a beer budget - kinda.
Has anyone spent time in a Dynaudio optioned VW? EOS, Passat, SUV, etc.
The MY07 Passat Dynaudio wagon I'd listened to was a solid A to B+ upgrade from a stock VW stereo. I hope this effort sounds good in the 993,,, because most if not all of the components are assembled.... Ready to tear open the interior.
Old 12-22-2010, 08:50 PM
H.H.Chinn
H.H.Chinn's Avatar
I was looking at these about a couple of months ago and wasn't quite sure if they would work on a CDR-210 and was waiting for some confirmation before placing an order.
Old 12-23-2010, 10:02 AM
JPP
JPP's Avatar
I'd ordered the Solisto unit so we'll see. (as soon as Santa get's his sleigh on the roof)
Sorry for being sooo sloow here, but I'm sound system challenged. So, the "interface" here is the factory CDC-3 trunk mounted 6CD changer that came as an option on 993's, correct? These Solisto units won't work with the CDR210/220 units without that trunk mounted unit 'in line' because the radio's don't have an Aux input and the Solisto box provides that in the form of broken out dedicated inputs for iPod/iPhone, digital recordings etc... Do I have it?
Old 12-23-2010, 10:57 AM
e9stibi
e9stibi's Avatar
Not sure if I understood correctly. According to Solito the unit will work with both CDR 210/220. You run this INSTEAD of the CD Changer. It emulates the changer and will be controlled from the head unit like a changer. THis is why the number of songs is limited that you can store on the Solisto. What you need is a CD changer cable because the solisto unit hooks up into this plug. If you already have a changer and replace it with the solisto unit in the trunk: piece of cake. If not, you need to get the changer cable and place the unit where you want.
Hope this helps.
Old 12-23-2010, 11:12 AM
JPP
JPP's Avatar
^^^ Yes, thank you for the clarification. As I understand it now, I can install this unit using a CD Changer cable (and based on its size, under the dash looks doable) and it will provide interface to run/charge my iPhone and store a limited number of CD's digitally and that music 'library' can be controlled from the head unit. I'm assuming I could also run iPhone Apps like iPod, Pandora and Tom Tom navigator through the car's stereo system at that point, but judging from the O.P.'s post, no one here has actually hooked one up yet to test it's actual capability. It does sound promising, however ...
Old 12-23-2010, 11:41 AM
M. Schneider
Was your interface concern the CAN BUS architecture? If so, mine also.
Other's before me say the presence of the CANBUS signal is irrelevant,, and that the amp/crossover device will function without its presence. We'll see??? On the flip side, one can never have enough paper weights!
Have a Merry..
Quick Reply: CDR-210 w/Ipod, Aux und USB inputs...
