997 GT2/GT3 Forum 2005-2012
Small tire sidewall bubble-replace or leave alone?
Old 02-05-2011, 12:34 PM
LonnieR
LonnieR's Avatar
Default Small tire sidewall bubble-replace or leave alone?
There is a small sidewall bubble on one of my front tires. Tires only have about 50% tread wear. My gut says replace both front tires. What do you guys think?
Also- isn't that condsidered a manufacturing defeat and should be covered under the tire warranty? Tires are Michelin pilot sports N4.
Old 02-05-2011, 12:44 PM
911SLOW
Admin
911SLOW's Avatar
Try the warranty but do replace both asap.
Don't play around with tires. Save money on other things.
Old 02-05-2011, 12:48 PM
Macster
Macster's Avatar
I'm pretty **** about tires. I'd replace both fronts with the same brand/n4 tires as are on there now.
Before you replace the tires you can arrange to take the car by a Michelin tire store and see if there's any recourse. While the presence of a bubble does indicate a defect in the tire, I'm not at all familiar with how long after purchase, how many miles after installation, new tires are covered for. I could imagine without some kind of tire warranty you may be SOL.
Sincerely,
Macster.
Old 02-05-2011, 01:31 PM
ADias
ADias's Avatar
Side bubbles are bad - they imply deformed strength elements (belts). i would perhaps patch a puncture in the center tread (which does not affect strength elements), but would replace a tire with a side bubble.
Old 02-05-2011, 02:57 PM
fuenfer
fuenfer's Avatar
I would replace both tires. The flexing of the tire will eventually cause the bubble to burst and turn into a sidewall puncture. Not something you want happening at any speed.
Good luck with the warranty - I've tried in the past, and have been told each time that I must have hit a pothole.
Old 02-05-2011, 03:31 PM
malmasri
malmasri's Avatar
No doubt, replace ASAP...never gamble with tires, odds never in your favor.
Old 02-05-2011, 03:40 PM
996FLT6
996FLT6's Avatar
I would replace both tires. Sidewalls are the weakest links- can't patch that. If you're planning to replace pop the bubble and see what happens? Mike
Old 02-05-2011, 03:52 PM
tcsracing1
tcsracing1's Avatar
i have had a few bubble tires in my time.
I always stick em' on my ol' daily driver mustang which gets all my porsche tire hand me downs.
They come from under inflation and pot hole strikes usually.
The bubble wont explode as there is another layer of rubber behind it.
You can actually take a blade and cut into the bubble and the tire will still hold air because of inner layer of rubber.
I drive em like this but only on my beater driver.
Im always close enough to home in the event of a flat which has happened.
This is not something you would want to take to the track by any means.
I only bomb around town with one on my mustang until the tread is wore off for new tires.
Aim for warranty, and then keep one as a spare and toss the bubble tire.
Old 02-05-2011, 03:56 PM
10 GT3
10 GT3's Avatar
First the bubble means that there is a structural failure in the tire. It could be a natural flow or that cause an impact with a pot, curb or road turtle. Bottom line, get it replaced whether it is under warranty or not. It is bubbling because the stiffening structure of the sidewall(case/belts) have failed. A thin layer of rubber is all that is keeping air in your tire. Hit just 1 bad pothole and enjoy walking home.
Old 02-07-2011, 06:46 AM
ir_fuel
ir_fuel's Avatar
bubble on the sidewall = structural damage to the tyre. Replace it ASAP because a pothole could be enough to make it explode.
Old 02-07-2011, 11:23 AM
CRex
CRex's Avatar
Not to be alarmist but the above comments are correct. Tire tend to fail at the moment you need the most grip out of them. Why gamble. I'll swap them rickety tick and seek recourse if/when available.
Old 02-07-2011, 06:20 PM
KBS911
KBS911's Avatar
Replace, replace , replace! That's a big hurt waiting to happen. 50% wear is nothing compared to your potential for failure. Just not worth the risk.
Old 02-07-2011, 06:41 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
One more vote to replace both fronts since at 50 percent wear replacing one will cause problems - car might pull to one side.
Quick Reply: Small tire sidewall bubble-replace or leave alone?
