Wheel Bearing Grease
Old 08-19-2011, 01:30 PM
xupkid2
xupkid2's Avatar
Default Wheel Bearing Grease
So I tried a search and didnt come up with anything. Wondering what people are using for wheel bearing grease in their race cars. I have typically ran Swepco 101 but was considering the Redline CV-2. Not sure what most people have had success with.
Thanks
Brian
Old 08-19-2011, 03:08 PM
sig_a
sig_a's Avatar
Mobil 1 Synthetic Grease....works well on skeet gun in cold weather, too. Packaged in can type container as well.
Old 08-19-2011, 03:35 PM
Kpoeltl
Kpoeltl's Avatar
The best you can buy for the older style tapered wheel bearing applications is Mobilith SHC 220 grease (available at Grainger among others places). This is what 100% of the NASCAR teams are running in thier tapered bearings. I learned this during a converstion with the SKF bearing racing products manager.
At approx $10 a tune you can't go wrong.
Karl Poeltl
Racer's Edge
Old 08-19-2011, 04:21 PM
Sterling Doc
Sterling Doc's Avatar
This sounds like it would work for CV joints as well, correct?
Old 08-19-2011, 05:24 PM
winders
winders's Avatar
I prefer to use TriFlow grease on my K-80......
Scott
Old 08-19-2011, 09:35 PM
mikew968
mikew968's Avatar
The mobil shc 220 is holding up very well for me. i was having problems before but the 220 solved it.
Old 08-19-2011, 10:53 PM
bgiere
bgiere's Avatar
Redline is excellent...I have used it for many seasons and the races and bearings are like new. NEO makes an excellent grease also I am told. If you have seriously hot operating conditions I'd look for some Dupont Krytox grease...It is virtually indestructible...but very expensive. My experience with M1 grease was not so positive. IMHO there are much better greases out there and the cost difference is not significant.
Old 08-20-2011, 12:33 AM
schwank
Herr Unmöglich
schwank's Avatar
So far Redline has done me pretty well.
Old 08-20-2011, 06:13 AM
sig_a
sig_a's Avatar
Scott
TriFlow oil on ASE 90 drop trigger.
For what it's worth, specs on Mobil 1 Synthetic and Mobil SHC 220 are virtually identical.
Old 08-20-2011, 09:33 AM
Lemming
Lemming's Avatar
I've been using the Redline with no problems.
Old 08-21-2011, 08:01 PM
Chaos
Chaos's Avatar
Redline
Old 08-21-2011, 09:39 PM
xsboost90
xsboost90's Avatar
swepco ftw.
Old 08-21-2011, 11:54 PM
xupkid2
xupkid2's Avatar
Thanks guys. I decided to go with Redline as its easier for me to get vs the Swepco. We will see how it works.
Thanks
Old 08-31-2011, 02:08 PM
ValveFloat
ValveFloat's Avatar
Sorry to hijack, but what about "sealed" bearings? Do you just use what is in the bearing, or have it repacked with a higher temp grease?
TIA
Quick Reply: Wheel Bearing Grease
