Saturn Studs for Exhaust Manifold - Where to Buy?
Old 09-20-2011, 10:05 PM
refresh951
refresh951's Avatar
Default Saturn Studs for Exhaust Manifold - Where to Buy?
Found the Saturn/GM Part number: 11518152
Anyone know a good place to order these?
Old 09-20-2011, 10:18 PM
kinglenario
kinglenario's Avatar
yeah, i got mine here. let me know if you have problems with the link. i haven't used them yet so if you need them right away and want to order a set to give me that would be fine.
http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214643
Old 09-20-2011, 10:19 PM
kinglenario
sorry, you need to search for part # 11518152
Old 09-20-2011, 10:28 PM
refresh951
refresh951's Avatar
Colin - Thanks man, perfect. Just ordered them. Might take you up on your offer if the machine shop has my head done by Friday.
Old 09-21-2011, 12:07 AM
gregeast
gregeast's Avatar
Glad you found a source.
My first thought was "just go down to the local Saturn dealership like I did" but that's not gonna work so much these days is it...
Old 09-21-2011, 12:11 AM
refresh951
refresh951's Avatar
That is exactly what I found in the old threads....
Old 09-21-2011, 12:14 AM
zerMATT951
zerMATT951's Avatar
Order 8 extra... those things are EXTREMELY handy on the intake too, and save time and money on future intake R&R's with LR rubber/aluminum gaskets.
Edit: I had to cut down one of the Saturn studs on the exhaust to get the rear nut on the #2 tube, there's no room at that spot with the SFR stage I headers.
Old 09-21-2011, 12:20 AM
zerMATT951
zerMATT951's Avatar
You can still get Saturn (Pontiac and Oldsmobile too) parts at most GM dealerships. They may have to order it, but the parts shouldn't be too far away at a regional warehouse.
Old 09-21-2011, 12:22 AM
refresh951
refresh951's Avatar
Cool, I ordered 12 extra just to have some laying around as they were only 84 cents/each.
Old 09-21-2011, 02:10 PM
kinglenario
i called all around and nobody stocks those in atlanta. easier to just order them online. what is the advantage to have them on the intake? isn't it just as easy or easier to use the stock bolts? the bolts are pretty easy...
Old 09-21-2011, 10:01 PM
zerMATT951
zerMATT951's Avatar
On a completely stock car, it may not make much difference. On a car with extra or new wiring harnesses, a billet fuel rail with a rear dampener, or anything else that makes the placement of the manifold a bit of a juggling act, the studs just make things simpler. You don't have to mess with gaskets that slide around if you miss the target once or twice, it just makes things simpler. Not to mention if you think you might have the intake off occasionally for maintenance or upgrades, you practically eliminate the risk of stripping the aluminum threads out of the head.
Sure, these are all minor things, but for less than $12, it's one of the cheapest mods you can do that will have repeated benefits down the road. If this will be the only time you are ever going to take the manifold off, or if you are just fixing the car to sell it, don't bother. If you plan on keeping the car until the doors fall off like I do, than it's more than worth that extra $12.
Old 09-22-2011, 10:51 AM
JohnKoaWood
JohnKoaWood's Avatar
I can say IMHO that the studs, and SS nuts make for better appearance as the OE bolts corrode over time... the studs and nuts... not so much!
Old 09-22-2011, 11:35 AM
zerMATT951
zerMATT951's Avatar
I used copper nuts just to match the exhaust nuts, but I may switch them to SS... that would actually look pretty darn good with my shiny intake .
Old 09-22-2011, 12:01 PM
JohnKoaWood
I am thinking the copper nuts will look sharp next to my intake... pics will come eventually... FWIW my intake has the same finish right now as my avatar...
Old 09-22-2011, 03:52 PM
Josh B
Josh B's Avatar
I was looking at these studs last night and they have a hex on the outside. Does anyone where you can buy the ones with the 5mm internal hex? I had some that were included in one of the hardware kit group buys that happened on the board.
Quick Reply: Saturn Studs for Exhaust Manifold - Where to Buy?
