993 Forum 1995-1998
CR-210 Radio issues.....help?
Old 04-10-2012, 12:03 AM
993inNC
993inNC's Avatar
Default CR-210 Radio issues.....help?
Unlike most here, I happen to think the stereo in my car sounds pretty good (I have the "hifi" option system not the basic system).
I took the car out tonight after reading about DiStephano's RSR build thread and a few others (hadn't driven the car in some time) and found my radio not working right.
I searched every radio post and only found one other having the same issue followed by useless responses.
The radio cuts out with the press of any button, it will turn on and off with the on/off button but any other button it just cuts off. I made it worse by disconnecting it when I got home now I can't even type the code in to get the radio back on (the radio shuts off)
This happened when I first bought the car, and for the life of me, I don't recall what I did to make it work again.
Anyone..............?
Old 04-10-2012, 12:17 AM
The Brewmeister
The Brewmeister's Avatar
I have the the same unit in my car. I would give Becker Autosound in Saddle Brook, NJ a call (no affiliation). They are the supposedly the last Becker repair facility on the planet and will probably be able to help. http://www.beckerautosound.com/
Old 04-10-2012, 01:06 AM
LJ993
LJ993's Avatar
+1 on Becker Autosound. I found the service department to be very helpful. the Guy at SW Stereo was also pretty helpful. good luck. Phil
Old 04-10-2012, 08:50 AM
ilko
Agent Orange
ilko's Avatar
Or just get a replacement off Ebay, they are in the $100-150 range.
Old 04-10-2012, 11:22 AM
davesnothere
davesnothere's Avatar
What about detaching the face and cleaning the contacts between the face and the body of the radio?
Old 04-10-2012, 12:07 PM
993inNC
993inNC's Avatar
I took the face plate off and opened it up all looked good and contacts couldn't have been cleaner. Thinking it's in the faceplate though so going to call Becker auto. I was able however to get the tape out of the deck by holding the pin receiver down that tells the deck the faceplate is on which is why I think the face is the issue. Well see
Old 04-10-2012, 02:12 PM
2Many Cars
2Many Cars's Avatar
Anyone near you with the same unit? If so try switching faceplates to see if that's the problem. I'm guessing it is.
If it is a bad faceplate, rather than buying a new one you might consider upgrading to the CDR-220. It's easier to use (***** instead of rocker switchs) and has a much better quality tuner and amp. By no means is it state of the art but IMHO it's 100% stock looking and has better sound that even a non-audiophile dweeb like me can hear.
Old 04-10-2012, 06:49 PM
993inNC
993inNC's Avatar
I just went ahead and sent it out. After 15 years, could probably use a service anyway and theyll send it back with the jack installed to plug my iPhone into it so no sense in playing around anymore. The guy assured me he'd send me back a working unit and the service has a one year warranty! Seemed reasonable. Probably a five dollar item and ten minute fix that'll cost me a couple hundred but I don't want an aftermarket deck in the car. I use it so little anyway ........
Old 04-11-2012, 10:50 AM
ehanauer
ehanauer's Avatar
A lot has happened in car radios since 1995. With Bluetooth I have my phone in my pocket, yet when I start her up, she starts playing my tunes or Pandora's.
Old 04-11-2012, 06:55 PM
993inNC
993inNC's Avatar
Yeah I thought that would be a cool feature to have too Eric but they wanted $650 for the Grand Prix with blue tooth and I just don't use the car enough to warrant that expense.
Old 04-11-2012, 11:14 PM
William D
William D's Avatar
Make sure the battery is fully charged. This happened to me intermittently until I got a battery maintainer, then no more problems.
Old 04-11-2012, 11:58 PM
Gt3 Racer RS
Gt3 Racer RS's Avatar
+1
Old 04-12-2012, 11:13 AM
ehanauer
ehanauer's Avatar
Alpine makes a unit with aux, USB, and Bluetooth for under $200. And it's simple look goes well in the 993 dash.
Quick Reply: CR-210 Radio issues.....help?
