How to turn off engine compartment light?
Old 04-25-2013, 05:32 PM
Doug_B_928
Doug_B_928's Avatar
Default How to turn off engine compartment light?
I've read some posts where people say they turn off the engine compartment light (when you want to have the lid open for an extended period of time without the light being on) by disconnecting it. How exactly is that done? On mine (06 C2S) the power to the light is separate from the power to the fan, so when I disconnect the fan the light stays on.
Old 04-25-2013, 05:54 PM
jhbrennan
jhbrennan's Avatar
It goes off by itself as part of the power saving function (see owner's manual) after about 2 hours. If you open the lid then set the alarm with the remote it will go off after about 20 minutes. From the manual:
If the ignition key is removed, loads which are switched on or are in standby mode (such as the luggage compartment light, interior light and radio) are automatically switched off after approx. 2 hours.
Two hours or 20 minutes - not enough to drain the battery.
Old 04-25-2013, 06:06 PM
Doug_B_928
Doug_B_928's Avatar
Excellent, thank you!
Old 04-25-2013, 06:20 PM
floatingkiwi
floatingkiwi's Avatar
Mine never comes on... voltage doesn't get to the light fitting.
Old 04-25-2013, 08:59 PM
Ptech1
Ptech1's Avatar
Close the latch with a screwdriver or hook tool. Car will think the lid is closed, hence the light will be off. Just remember to release it before closing.
Old 04-25-2013, 10:48 PM
Edgy01
Poseur
Edgy01's Avatar
Ditto for Ptech1's solution. Works well and reduces the battery drain during extended engine work.
Old 04-25-2013, 10:54 PM
Doug_B_928
Doug_B_928's Avatar
Very clever workaround.
Old 04-26-2013, 10:01 AM
Spiffyjiff
Spiffyjiff's Avatar
technically, shouldnt the battery be disconnected if one is doing the type of engine work that would require an open lid for an extended time? (hey, i aint one to follow the rules - i rarely disconnect my batt even tho i probably should at times - but just thought i'd ask anyway!)
Old 04-26-2013, 08:28 PM
Ptech1
Ptech1's Avatar
Not necessary unless dealing with voltage sensitive modules in that are not located in the engine bay of these cars. The starter and cable are about the only thing requiring a battery disconnect. Besides, disconnecting or disrupting battery voltage can cause more issues and faults than working around it. In fact, when I replace batteries, I keep a jump box plugged into the lighter socket in order to not lose memory storage, etc...
Old 04-27-2013, 12:04 AM
Edgy01
Poseur
Edgy01's Avatar
Don't disconnect the battery if you don't really need to because these complex cars like to keep a little voltage going through them to keep them happy. If you resort to pulling the plug, they take some time to adjust back to having the power. (Certain reinitialization events have to happen). Keep your life simple--avoid pulling the plug.
Old 04-29-2013, 05:27 PM
AWay
AWay's Avatar
I often pop the rear lid after a good drive just to let all the heat escape and be kinder to the rubber parts back there. As I never poke around in the engine area in the dark, I simply removed the bulb. No more light and I can leave the lid open as long as I'd like with no battery drain.
Old 04-29-2013, 05:56 PM
jhbrennan
jhbrennan's Avatar
Too much work...just wait 2 hours and it will go off by itself.
Quick Reply: How to turn off engine compartment light?
