FS: NIB DOT-Legal Hella H4s
Old 06-10-2013, 05:32 PM
ideola
Former Vendor
ideola's Avatar
Default FS: NIB DOT-Legal Hella H4s
Had an ordering mixup for some Hella H4s, which means these brand new-in-box DOT-Legal H4s are available for immediate shipment.
Price: $108 plus shipping
To purchase: http://garage.ideola.com/used-Body.h...34631989826498
Old 06-10-2013, 05:37 PM
Bilal928S4
Bilal928S4's Avatar
Do these fit a 928?
Old 06-10-2013, 05:50 PM
ideola
Former Vendor
ideola's Avatar
These are the standard 7" H4 circular enclosures, so yes, I would think these will work for pretty much any of the Porsches that use 7" bulbs.
Old 06-17-2013, 11:58 AM
ideola
Former Vendor
ideola's Avatar
Still available.
Old 06-17-2013, 11:38 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,253 Likes on 1,247 Posts
these lights would swap in for the 7" sealed beams
Old 06-20-2013, 01:41 AM
Barry Chan
Barry Chan's Avatar
How much brighter is it compare to the stock beam?
Is it plug and play?
I have a stock 84 us
Old 06-20-2013, 08:20 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I have a Bosch set in my '85 and the difference between the sealed beams and the "7 H4 is HUGE!!! Excellent upgrade. The only thing I'm not sure if any H4 is DOT approved or not. Don't remember seeing any DOT marking on the lenses.
Old 06-20-2013, 10:35 AM
davek9
davek9's Avatar
From the pic, they look to have the Adjustment dimples on the front, the ones I picked up from Roger do not, so that and focus could be the difference in the DOT lenses.
I like having the option of being able to change the type of bulb that the H4/H5 gives you. Wish these came up a few week earlier.
Dave
Old 06-20-2013, 10:47 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
NOTE the BIG lights on the 928 are 8 inch diameter,
these lights are smaller diameter and will not make as much light as the 8 inch units will,
due to less reflector area.
That said they are an improvement over the sealed beam units found in most of the US early cars
Old 06-20-2013, 11:35 AM
76FJ55
76FJ55's Avatar
It appears as though these are DOT approved. IIRC there are technically DOT reflectors with 9003 replaceable bulbs. The 9003 uses the same format as H4 however 9003 is DOT approved for cars and H4 was not. Many bulbs are qualified to both 9003 and H4 as the specs overlap. The H4 reflectors were not DOT legal for cars, however, you can get H4 DOT motorcycle headlights. The primary advantage of the Hella Vision plus is that it gives you the ability to run uprated bulbs while still running US DOT approved reflectors. From what I’ve read the choice for pattern would be Euro H4 8”, Euro H4 7”, Motorcycle DOT H4 the then the US auto DOT Hella. The Motorcycle lights are readily available, and at very reasonable prices, so it seems to me that the deciding factor will be how important one finds the DOT approval. If you want DOT approved car headlights these are the ones to get.
Old 06-20-2013, 02:12 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
So these are motorcycle lenses but are the same diameter as the "7 European automotive H7s but they have different lense pattern than the automotive ones?
Old 06-20-2013, 02:43 PM
76FJ55
76FJ55's Avatar
These are automotive 7" round DOT approved healights which come with installed 55/60 HB2 (9003) Dot approved bulbs. Edit: (these are not technicaly H4 as the initial post suggests). This is as good as it gets for automotive DOT approved 7" headlights. These headlights will accept H4 bulbs (not DOT approved) which are available in hight power output.
The only H4 reflectors with DOT approval are for motorcycle. they are available in th 7" round configuration so some people install them in cars/trucks, as they have a better beam pattern, and though they do have DOT on the lense it also displays "MOTOTCYCLE" on the lens, so technically not DOT applicable to cars.
Old 06-20-2013, 03:51 PM
Barry Chan
Barry Chan's Avatar
I went to his site and it says DOT legal....
Is it worth the swap if it only be just a little brighter for $108.00 plus shipping?
Do i lose the chrome rings on the headlamps?
Old 06-20-2013, 05:16 PM
76FJ55
76FJ55's Avatar
No these will NOT lose the chrome rings. these are direct fit replacements for your existing headlights.
Do you care about DOT approval?
If yes: then these are as good as it gets.
If no: there are better cheaper optioins. $44.95 H4 Euro 7" pair from busdepot, for example. what I'm running in the Range Rover.
Old 06-20-2013, 05:43 PM
ideola
Former Vendor
ideola's Avatar
These are DOT approved, they do take H4 bulbs, and that is the big advantage over sealed beams is that the bulbs are replaceable by a range of modern light elements, while being loaded into a DOT approved fixture. FWIW, the DOT approval has nothing to do with the bulb; it is the dispersion pattern of the fixture.
As for the difference between e-code and DOT-legal, these are the differences between E-codes and the Vision Plus DOT-legal versions:
1. Lighting pattern
The US DOT mandates a dispersed pattern that puts a percentage of the light output up and to both sides of the road so that overhead or roadside signs which may not have other lighting or reflective characteristics are illuminated by the headlamps.
The European standard allows all the light to go on the road because European law mandates that overhead or roadside signs have independent lighting or be printed on highly reflective backgrounds.
2. Aiming lugs
DOT also required that the lamp have the three aiming lugs on the face of the lens. This requirement was dropped in the 2000 DOT Standard when visual aiming was approved. The Vision Plus lamps still have the Aiming Lugs, E-code lamps do not.
3. DOT-labeled
The lamp must have DOT molded into the face to confirm that it meets DOT. E-code lamps have E1 molded into the lens.
4. Bulb brightness
DOT limits the lamp output to no more than 60 watts on high beam and 55 watts on low beam. The Vision Plus comes with a 60/55w H4/HB2 bulb in it in order to meet the DOT standard. The E-code lamps are available with a variety of bulbs in various wattages and color temperatures. It is generally a bad idea to use different bulbs in the Vision Plus enclosures because of the aforementioned light dispersion pattern, which could cause brighter bulbs to blind oncoming traffic.
Hope this helps!
Quick Reply: FS: NIB DOT-Legal Hella H4s
